RCA Question
  • 2
MDamman23011
10
Michigan
In a 2008 BMW 335, I have the LOC wired and a JL 500/1. I have 3 different sets of RCA cables so I know they ALL can't be bad. When i plug them into the LOC and run them to the amp, the sub barely moves. But when I take one of the RCA cables out and touch it to the outside of where it plugs in, the sub then hits like normal. What could be causing this problem? Bad RCA inputs on the amp I am thinking? If so, how would I go about repairing them?
Sounds like something is loose. Does the rca terminal on the amp wiggle around at all? I don't know if the warranty is void if you pop open the back, but if it doesn't void it I would take a peak. Could be a loose solder joint somewhere.
no movement in the RCA terminals
Do you have a dmm? I would probe around and see if you can find any weak parts of the terminal. Also make sure there is nothing inside the RCA itself. Some dust or random fuzz that finds itself in the terminal will ruin a lot of conductivity.
no I do not have one of those but I am checking to see if a friend has one I could borrow and I will check to make sure of any dust and what not
Use a toothpick or a paper clip and lightly try and pull anything out that may be in the rca. Make sure not to break anything off though lol
well i hooked up another amp my buddy gave me...everything works perfectly
I am happy to say I have yet to hook up a system and everything works the first time (wire wise that is) but disappointed I was the dumb *** that bought a used amp. Well i guess you learn from your mistakes and move on. There are some ****** people out there.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
873
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
906
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
759
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
851
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
942
MDamman23011
MDamman23011
Michigan
MDamman23011
