Rca connection slipping
  • 2
TDot
Bronx
Every once in a while a specific rca connection I have slips off due to sub vibrations I guess. The wire is very tight and strong, but once in a while it comes off. It's most likely because it is set up vertical instead of horizontal due to space requirements. Any ideas to make it stay on?
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
884
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
926
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
771
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
862
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
11
950
TDot
TDot
Bronx
Aygodriver1212
