Dj-torn 10+ year member
Still learning...
Would i be able to hook up 6 SVC subs, 60W RMS each, 4 ohhms each in this manner, since the amp is 3 mode capable?; If so what would be the RMS on each speaker?
Left Channel 2 subs @ 2 ohms -
|- 2 Subs @ 2ohms
Right Channel 2 subs @ 2 ohms -
PA GOTHIC OV2-500
Specs:
2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 125W x 2
THD at 4-Ohm RMS Power: 0.02%
Bridged RMS Power @ 4 Ohms: 300W x 1
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 18 dB
Frequency Response: 10-30,000 Hz
Signal to Noise Ratio: 97 dB
Fuse Rating: n/a
|- 2 Subs @ 2ohms
PA GOTHIC OV2-500
Specs:
Preamp Outputs: Yes
Bass Boost: 18 dB
Fuse Rating: n/a
