Question about the benefits of a stainless coil former
  • 1
shredder2
CarAudio.com VIP
3,240
605
Az
It's recone time for my sub, I lost a coil and since I have a daily sub with the RS Plat 18 I'm trying to find some gains with my current box/amp setup.
It's for a FI Blv3-18 and I was originally thinking D.7 coils to wire lower along with an extra spider to control the mass with the added power, wired like I was at .5 I could make the coil tap at full power. That was with a standard FI recone dual 1 coils /w/ 3 spiders.
FI said the D.7 aren't available currently and offered a True dual 1 /w/ stainless former as an alternative for a burp only setup.
What I'm wondering is since I have a daily sub and will use the FI for burps only what will be the major changes with the stainless former?
Different weight? will the added metal in the motor add force or something like that.. or will the added mass be a wash with the motor force increase or will I need an extra spider?
I'm thinking the stainless former coil might be a tighter gap because it's for only burp applications and also the coil won't handle heat as well... :unsure: ... I've been warned... "being stainless on the former and aluminum on the winds, it has a dissimilar expansion ratio and will not take long term heat for music. Gains for burps, will unwind on high power music."
My coil WAS tapping at full burp...
20154
But it ultimately failed here...
20155
I was consistently clamping just under 3K or so at .5, How will the "stainless former", "true D1 coils" affect my clamp and should I get that extra spider this time?.. I ordered it with an extra last time but upon inspection it has the standard 3 spider pack.
Depending on tuning (41-45hz) I could clamp 2800-3500 watts at 47hz for a 152.4db before. What happens now?.. lol
Any thoughts and advice from you more experienced guys would be welcomed before I order the new recone.
I'm assuming a lot but know enough to ask before diving right in.
Thanks in advance for any advice/guidance regarding this.
It's recone time for my sub, :unsure: ... I've been warned... "being stainless on the former and aluminum on the winds, it has a dissimilar expansion ratio and will not take long term heat for music. Gains for burps, will unwind on high power music."
No replies... hmmm...
I was told this just today... "The stainless former reduces inductance and eddy currents and usually sees consistent gains over a regular recone/former."... I DID specify a burp only usage so once it arrives I guess I'll be swapping subs on that day.
Until then... I'm tuned lower for daily and can adjust tuning to burp when necessary.
I thought I'd share this info since countless searches I did were all to no avail concerning this, I hope someone finds this useful.
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
394
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
757
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
998
shredder2
CarAudio.com VIP
shredder2
Az
shredder2
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
