Problems with my 3.5 Farad Capacitor
dags_07
Ok, I have 2 Alpine Type-E 12" connected to a Boss PH2.800 1600w amp (2 x 260rms at 4ohms) and a 3.5 farad capacitor. Now, I have a little issue with the capacitor, when I turn up the volume for more than 20 the voltmeter goes off and the capacitor start making a beep sound.
I have a 4 gauge ground cable for the capacitor, but I am still waiting the one for my amp (I am currently using a regular speaker wire as ground for the amp, I know I shouldn't be doing that at all, but I wanted to test the bass a little.)
Another thing, both ground cables are connected to the same place, is it the problem?.
What do you think why the capacitor goes off and starts the continuous beep? I leave you guys some pictures and a video to better describe what is happening
Video: the video is on youtube, just look for Problem with my Capacitor. Any help?. I couldn't put the link.
Thank you
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
so many n0obz with caps. ditch the cap. you should be better off.
wait.....wat?
My lights dim a lot without it, I can't afford a more powerful alternator //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
the cap is dead. you need to either replace it or junk it. i saw junk it.
The cap is brand new :S
---------- Post added at 05:31 PM ---------- Previous post was at 05:30 PM ----------
get a 4ga ground for the amp and try it again, also take the amp off the box, its not good for the amp to be mounted that way. (vibration)
Thank you for the help, some people has told me that it could be the ground, it should came on the mail soon
please for the sake of your car, do not run this setup like it is. speaker wire grounds and beeping caps //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
and my amps are on my box. been there for years //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I know I !@#$ using the speaker wire as ground. That is why I bought a 4 gauge coming soon on the mail. The beeping cap is what is annoying me. Another solution for light dimming?
so why not wait until the wire comes in? and a battery or an alt is the solution here. possibly even the big 3
I will wait for the cable, and if it is not the solution I will do the big 3. And if it not the solution, I will burn that ..... cap and buy a alternator and a battery.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
884
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
851
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
dags_07
dags_07
Weston, FL
jco1385
    Jun 1, 2024
    May 31, 2024
