Problems With Alarm
  • 3
BonusBobo
Lightweight Sesh
I got an AudioVox Prestige alarm today, and it worked fine and I thought it was pretty sweet at first. but then tonight at about 10, I pressed unlock, and nothing happened. so I pressed tons of buttons and it went into panic mode, after which I waited 30 seconds, and it went off. So I eventually ended up disarming the alarm after a few attempts at pressing the button. The same thing happened when I arrived at my destination and tried to arm the alarm. Can anyone tell me what I did wrong? I swear I pressed the button right. If you can't help me, just tell me I'd be better off talking to the guy who installed it. Give me some recommendations. I'm really concerned.
Originally posted by BonusBobo I got an AudioVox Prestige alarm today, and it worked fine and I thought it was pretty sweet at first. but then tonight at about 10, I pressed unlock, and nothing happened. so I pressed tons of buttons and it went into panic mode, after which I waited 30 seconds, and it went off. So I eventually ended up disarming the alarm after a few attempts at pressing the button. The same thing happened when I arrived at my destination and tried to arm the alarm. Can anyone tell me what I did wrong? I swear I pressed the button right. If you can't help me, just tell me I'd be better off talking to the guy who installed it. Give me some recommendations. I'm really concerned.
Your first mistake was buying an Audiovox alarm. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I would take it to the installer and desribe what you said. I have known many people who have had them installed. And the system worked for a week or so then crapped out. Not the greatest quality of alarms //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well, it works fine now. I think I just needed to figure out how to work it. ***** a bought a shitty alarm though. Hopefully it won't crap out like your friend's did. Meh.
dont believe the hype about alarms being better than others, they are just boxes with relays that lock when you apply voltages to them, plain and simple.
you probably re programmed something when you started hitting buttons...when ever you have a problem with alarms its usually the remote, either the battery isnt making contact or the button isnt touching what its supposed to touch.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
936
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
868
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
BonusBobo
Lightweight Sesh
BonusBobo
San Luis Obispo, CA
BonusBobo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
