Post Big 3 Issues
Knowmadic
I just finished up the Big 3 and am running into some issues, but isn't that what always happens when you do anything audio related to the car? So I hooked everything up, Alt + to Batt +, Battery - to Chassis, Engine Block - to Chassis. All surfaces were power sanded, and then I placed the ring terminal of the 0ga wire first, and the stock terminal on top it, and reinserted the screw. So far so good? I go to start my car and it's acting like my battery is dead, all it does is click.. Any suggestions/advice? I've got it on a charger right now and will attempt to start it up in the morning.
Check the battery terminals they could have come loose when you were disconnecting then wires. Can almost bet you have a loose terminal
I had a problem with this too at first. Did you keep your stock alt wire and added another wire. At first I didn't use the stock wire and went to turn it on and got the result your talking about. My alt wire had a sensor wire tied into it. When I redid the wire and use the stock wire plus my new wire it turned right on
^^^^^^ this *^^^^^
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over...
448
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
9
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Knowmadic
Knowmadic
Winchester, VA
bradl79
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
