porting a 1 cube box?
  • 3
winkychevelle
quick question. when i normally port a box i use a minimum 4 inch port. but in my current case im porting a pre-existing truck box. if i use a 3 inch port for the 1.07 cube box i can tune to 30 hz no prob. but i can only only achieve a 30 hz tune and keep the same volume.
now this is a 2012 p3 shallow 10 and rockford recommends 1 cube ported to 47hz with a 4 inch port 12inches long now i know this is not optimal for my listening preferences.
since this is a low excursion sub i figure i can skimp by with a 3 inch port. even if i have to sacrifice output id rather tune it low
and i have talked to rockford directly bout tuning the sub low. they just stated that i would lose output which i can live with if i can keep the sub from interfering with my mids around 70-80hz which i can do now with my 24db slope crossover but i cut out pretty much all the bass
i have a good bit of power on tap considering the subs only rated at 300rms and really doesnt need that imho.
opinions? this is a rockford employee order so im getting a good deal on all of this. the only other sub i will consider is the stereo integrity bm shallow which are darn near impossible to get.
sorry for the long read
I just read the other post about this Bass Cube. IMO, it sounds like a signal leveler with adjustable Q. For that you can just use one of the many...
Wrong again. Keep trying. Bobby isn't my real name and I don't live in Vegas.
30
3K
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
661
winkychevelle
winkychevelle
Ponchatoula, La
brandinooooo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
