port size/ length, input and help needed
  • 2
southernboom88
Shut It Down Boyz
227
ATL.
Just wanting to double check my numbers. Just build a box for 2 sa12's, 4.11CuF after displacement, will be seeing about 1800 watts rms. this will be a daily system that i may enter in some comps. thinking tune to 33hz via aero port. I'm thinking a 6" flared port, precision port calc says it should be 13.6". does that sound right? Any input on a diff tuning or route is welcome. Thanks in advanced.
If you've already built the box and plan to put a vent inside it, you will change the internal volume of the box and thus, not get the tuning you desire... unless you do a lot of vent displacement calculations in order to find your tuning.
It's a good idea to calculate tuning, vent, sub & bracing displacement before you build the box.
But yes, that length sounds right for 33Hz if the vent doesn't change the internal volume of the box.
thanks, I did account for the displacement of the port itself. I believe the calculator i used accounts for this as well.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
836
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
985
southernboom88
Shut It Down Boyz
southernboom88
ATL.
southernboom88
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
