Port of A 4th Order
I'm just weird like that I guess.. If it's complicated then it's me lol
Sent from my SM-N920V using Tapatalk
It's def not you. Some people have a hard time getting one.....but takes practice and testing. Not something that can be done overnight. You read what Jeff's buddy did...
6 sa 12 in a flatwall can get downright nasty. Me personally, i prefer the sound of flatwalls. I think they are more brutal... and ive heard many 60+ flats, 4ths, and 6ths
yeah, 4th order will kill higher frequencies super fast like literally dead a few hz right after port tuning, I would not recommend it. You'll have much better luck with flatwall with what you want. Thats basically the ideal bandwidth you achieve with flatwall but you'll play a bit lower as well down to 25hz or so and still hurt in the 50hz range.
Ummm....no, not even close to correct information. My 4th plays 25-60hz rather loudly as do most that I build. All about sealed size, ratio, port tuning. Lot of guys build 4ths to play into the teen, so those will fall off and octave or so higher but that's not the "typical" 4th....
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
849
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
996
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
daltone34
daltone34
US
mlstrass
