Popping Noise + In and out of protect mode
  • 3
KelanF
CarAudio.com Newbie
I am currently trying to install a active subwoofer into my mk7 Fiesta ST, everything is fine with RCA cables unplugged, but as soon as the RCA cables are plugged in it constantly makes a popping noise and goes in and out of protect mode
The cables are spliced into the rear speaker cables using t-taps, could it be due to this connection being dodgy?
This is my first install so explain in as simple terms as possible cheers haha
I know its not an issue with the sub as it was installed in another car fine
And what brand / model powered sub?
You mention T-taps, that's direct connecting RCA cable to rear speaker wire if I'm reading right? If so, yeah not supposed to do that.
I ask the exact model, as it may have high level inputs that you could switch to. Does it have other inputs that say high level on it? If not you'll need a line out converter, and hope you didn't damage the amp connecting to the cars speaker wires.
ringer ringer, chicken dinner... its your headunit. gotta upgrade mine as well, does the same thing, it cannot handle the additonal speakers, just...
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
367
Wow that is very very odd. Could be the wiring harness from them. Check the wires and possibly reground the stereo to another bolt in back of the...
13
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
10
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
KelanF
CarAudio.com Newbie
KelanF
Kent, England
Deiimos
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
