pls help
  • 5
my old Kenwood sub is sick....i termlab'd that shyt..hit 145 db in free air no box //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif duno what your problem is....
if i wasnt going to start over what would you recommend i do first? buy/make a box?
u need to see how much power u wana run. then see what it will take to run that. if u wana run 1000 watts u need at least 4 ga wire. u can leave your battery under your hood and do the big 3 wire up grade in 1/0 wire. u can find a amp and then pick out a sub. u need to build a box or buy one that will best suit your sub. some subs like low tunning some like higher tunning. some subs like sealed.
he might have a simple issue but it looks to b a mess. im not trying to b a di ck im gona do my best to help him
I would call Kenwood Tech support. Im sure they will try to help you
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
142
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
444
imanerd2
imanerd2
festus, MO
1rockford1
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
