Pioneer car amp turns on and off repeatedly
  • 2
Datring2000
CarAudio.com Newbie
10
Dallas
Long story short my amp has been working fine until recently. Suddenly, it started powering on and off every time I connect the red battery wire to the positive terminal of the car battery. This actually started happening after I blew the fuses on the amp and got new ones but maybe that has nothing to do with the amp.
Anyways, I thought the battery was the issue so I bought another battery and it’s still doing the same thing? I thought the issue would’ve solved.
could the battery wire be an issue? The wire melted after I installed new fuses on the amp. However, the wire is still able to power the amp that continued to power on and off
If I need to clarify anything let me know
First thing that comes to mind is a loose connection somewhere, but since you mentioned that you have melted wires, I would double check that everything is connected properly in terms of voltage/amps.
You can easily determine if it is the battery wire, but connecting a voltmeter to the cable while the amp is turning off/on to see if the voltage through the cable is steady. Follow that trail all the way to the amp terminal. If it is steady at the amp terminal, then you know it is the amp.
It could also be your remote turn on wire, or even your head unit telling the amp to turn off/on through that wire.
Start with the battery cable and go from there.
True, and why I state, all things considered equal. There are a multitude of variants, but that foundation is where you start and build from...
18
I have no idea how to share the link with my phone but i found tgese on ebay ....
8
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
457
Datring2000
CarAudio.com Newbie
Datring2000
Dallas
SonicRed
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
