Pioneer & Playlists - P6900UB supports while P600UB (Premier) doesn't??
  • 4
zzoinks
I recently installed a Premier DEH-P600UB and so far I've been loving it. I've had success with both a 4GB USB thumb drive and a 250 GB Simpletech 2.5" USB hard drive. So far, so good.
Today I decided to try and create a playlist. I created one in foobar2000, it wasn't recognized. I tried creating one in WMP 11. No dice. Thy simply weren't listed when I browsed the files on the head unit.
I compared the manuals between the older P6900UB and the P600UB. WTF?! It states that the p600 does not support playlists. What gives? They dropped support for this?
Has anyone had success using playlists with the P600UB? If so, what did you use to create them?
Thanks,
-Brett.
I also have a P600, but have only used the Playlist function on my iPod (Classic, 160GB). I'll test this out with a flash drive and get back to you.
Thanks! I'd love to know if it works for you. I don't have an iPod so I can't try that out.
-Brett.
Unfortunately, I didn't have any luck with it. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I stuck a .m3u and a .wpl file in the root of my flash drive, then the same files in a directory containing some mp3s. The P600 went straight to this directory and began playing those files, but the playlist files didn't appear in the list menu. I couldn't find a way to select them in the various menus.
It really is odd that they dropped this function. It does recognize iPod playlists fine, though.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
zzoinks
zzoinks
Cleveland, OH
TurdFergueson2
    May 24, 2024
