Phone Mute Lead - Wiring Harness
  • 1
illa.kotilla
I'm installing my first head unit with bluetooth capabilities. I purchased the Clarion FZ709 and the Metra Wiring harness that goes with my vehicle. Everything hooked up fine with the color coding, except for one problem, there is a wire that goes from the HU harness that is for the Phone Mute Lead. However, the metra harness doesn't have a brown or maroon wire to connect it to. The only wire left is the orange "Dimmer".
In the Clarion HU instructions it says "The lead included with the unit must be connected to the specified position of the vehicles ISO connector in order to use the "triggered audio mute for cellular telephones" function.
Unfortunately the Metra harness doesn't have a brown/maroon wire to connect it to (even though the packaging says it does).
So, I'm assuming this means one of two things:
1. The wire isn't necessary and I can cap it and the functionality will be fine.
or
2. I need to hook it up somewhere and I'm too stupid to figure out where the Phone mute lead is suppose to go.
Any words of advice?
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
I got my microwave hooked up to my stereo...the bass drop when my hot pocket is done is quite frankly breathtaking...
5
It all works fine, I had to change the Bluetooth connection type on my iPhone from being blank, to car stereo
4
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
5
I don't know about the charger, but here's what I picked up for a mount. If you know just about every phone mount, GPS/Garmin/GoPro, etc...
illa.kotilla
illa.kotilla
Bend, OR
illa.kotilla
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
