Orion HCCA 5 1/4 BNIB
  • 2
Whattha
Oklahoma
Orion HCCA 5 1/4 Components BNIB
5-1/4" HCCA Series Component System
Power Handling:
Peak: 200 watts per set / 100 watts each side
RMS: 100 watts per set / 50 watts each side
Kevlar/paper composite cone
Polyester foam surround
1" Silk dome tweeter
External crossover with 12 dB high pass and 6 dB low pass filters
Tweeter level adjustments
Custom tweeter mounting kits
Single flat interlaced conex spider with tinsel leads
Custom cast aluminum basket
Complete with mounting hardware
4 Ohm impedance
Copper clad aluminum wire voice coil
Neodymium magnet
Sensitivity: 90dB
$100 shipped
I have had these for about a year and have been collecting dust in my closet. Comes with everything that it came with from the factory.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
Ive had to install a 40 amp relay on the remote due to Popping issues on one my older Eclipse HUs, That ended up solving my popping issue. One...
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Whattha
Whattha
Oklahoma
hedgehog
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
