Old School PPI Sedona Series 500IQX (made in usa surfboard amp)
Spooney
Cosmetically I would give the amp a 7 out of 10. It has its share of scratching/scuffing but overall is very presentable .This amp isn't small by any means. It measures in at 2 feet long! Functionally/Electronically its a 10 out of 10. Works like a champ. Rated for 250x2 into 4 ohms and 700 watts rms bridged into 4 ohms but i'd expect a bit more out of it(old school made in USA PPI quality). This amp does have a built in crossover but the crossover frequency is controlled by what is called an SIP chip installed the end of the amp. I have a 90 Hz SIP chip installed and you can either highpass or lowpass around that frequency. Other chips can be found on ebay to custom tailor the crossover to your needs. The amp will function without the chip in full range mode or if you do have the chip installed the crossover can be defeated with the push of a button. All the terminal screws have been replaced with allen head screws as well. Kind of goes without saying that this amp sounds great. I had it running my sub and the bass was super clean and defined. Would be a great high powered front end amp as well.
200 Shipped in the lower 48 only. Please feel free to PM with any interest offers or questions. Trades considered but mainly looking for the cash
Shipping included in price. Most likely will ship either USPS or FEDEX
Sorry for the terrible pics. I will get better ones as soon as I can get it pulled from the car. Update: Nicer Pics Added Below!!!!
Yes these are bridgeable although it is not listed on the amp. It is the left positive and right negative I believe. I verified this with my multimeter and oscilloscope. Many older amps were not bridgeable but most of those were even before this amps time. Certain orion amps needed a separate module for bridging (old school gx series and other first gen orion amps)
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Spooney
Spooney
Charlotte,MI,USA
Spooney
