oh no noob question....
  • 4
BoomBoxStereo
@woofergram
do i need to have two speaker wires running into the + and - terminals like this diagram says? wouldn't putting two seperate wires into one terminal be unsafe? if i plan on putting in 8 gauge speaker wire i don't think two ends of 8 gauge wire will fit into one terminal... help me better understand this. i'm brain farting. it's late...
All negatives go to the negative on the amp, and all positives go to the positive on the amp.
but what i'm saying is that (on the left sub in the diagram) it appears that two seperate wires go into the top left positive terminal. is that correct?
Yes that connects the positives from the other sub (wire 1) and the positive from the other coil (wire 2).
okay just wanted to make sure i wasn't going to fry anything if i put two seperate wires into the one terminal... but now if i switch to 8-gauge speaker wire, how will two different 8-gauge wires both fit into the tiny positive terminal on the sub?
8 gauge is WAY overkill, unless you are running tons of power and chasing .10's. And it will not fit in most terminals.
I can assure you that you would not hear a difference between the two.
my amp has two positive inputs, and two negative inputs (for speaker wire)... should i use both sets of positive and negative on the amp, or just one (for one ohm)?
here's my amp................
8 gauge FTW.... lol
connect the 2 8 gauge wires togerther then take another single wire. connect the 2 wires to the single wire and run the single one into the amp. thats what i had to do with my temp amp i have in now because the terminals were 2 small for my 6ga or 8ga speaker wire.
8 gauge FTW.... lolconnect the 2 8 gauge wires togerther then take another single wire. connect the 2 wires to the single wire and run the single one into the amp. thats what i had to do with my temp amp i have in now because the terminals were 2 small for my 6ga or 8ga speaker wire.
what do you mean?
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
BoomBoxStereo
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
