Official CarAudio.com Big 3 Thread
I used 1/0 awg from KnuKonceptz. I do have 14.5 ish volts running accross the poles on the battery, and it only drops about 1 v when it hits.... but it does result in dimming. Come to think of it, the lights dim ever so slightly, for a split second when I use the power windows too (without the stereo on). Do you know if Partsource does free electrical system checkups?
i get the same thing with the power windows and the dimming. I thought we had the same cars, but we don't. I have a 98 Lumina LTZ. Is that normal? If you find out let me know!
has anyone here done the big 3 for a 01 cavy if so post pics thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What size fuse should i use with 1/0 gaguge wire with a 240 alternator 250a?
Yeah, that would be fine. Unless the alt make more power at higher RPM's.
I have a Ford F-250 with two batteries under the hood. Should I just make it the Big 6?
Just run two lines from the alt to the batteries and one from each of the negatives to a common spot. It would actually only be the Big 5 in your case.
Looks like I called this one correctly and OP hasn't been back to post any glowing reviews either.
21
5K
  • Locked
Watch out For USER ID: theasw232 and email mikescott6678@gmail.com !!!!! You've been Warned!
johnecon2001
SSA/ROE Super-Møderator
johnecon2001
Phoenix, AZ
2023 LTZ
maylar
    Jun 2, 2024
    Jun 1, 2024
