Next forum bonor?
anyone who comes here and is active in the classifieds is not here to look for the expensive brands like dd or JL which is why most do not recommend them.
Online forums for car audio is mainly for people looking to buy used cheap stuff because they cant afford the new stuff.
Im not saying all, but most do or else everyone would find the local genius and learn from them and not a forum.
if i see someone new, i usually ask for budget and go from there if they are asking for recommendation's.
The Ethos, DSS’s first product, was designed with two goals in mind. Tight articulate bass and the ability to work in small vented enclosures.
A stiff high pressure kraft fiber reinforced cone with a multi-layer foam surround is used to accommodate the 32,5mm of one way xmax. To handle the 1,800 watts of recommended power necessary to push the cone to xmax a rugged 3 inch 4 layer flat aluminum wire coil wrapped on a black anodized aluminum former is used. To ensure music is tight and articulate four eight inch true progressive spiders are utilized along with a FEA optimized 50 pound motor structure.
FEATURES
1,800 WATT RMS RATED
TRIPPLE STACK 8.6 INCH OD MOTOR STRUCTURE WITH BLACK CHROME FINISH
FOUR PROGRESSIVE SPIDERS WITH WOVEN TENSIL LEADS
NICKEL PLATED PUSH TERMINALS
HIGH PRESSURE KRAFT FIBER REINFORCED CONE
MULTILAYER FOAM SURROUND
WRAP AROUND RUBBER GASKET
3 INCH 4 LAYER FLAT ALUMINUM COIL ON BLACK ANADIZED ALUMINUM FORMER
DUAL 1 OR 2 NOMINAL IMPEDANCE VOICE COILS
SATIN BLACK CAST ALUMINUM BASKET
T/S PARAMETERS
Re 3 ohms
Le 2.94
Qms 6.19
Qes .845
Qts .74
Fs 23.75 hz
Mms 448.6 grams
Cms .1 mm/N
BL 21.43 t/m
Vas 181.85 liters
SPL 88.26 1m/1w
Xmax 32.5 mm
Power 1,800 Watts
NOTE: All parameters were extrapolated via a Klippel analyzer using LPM and LSI measurements. The recommended power rating is not a max input power rating. It is the necessary power needed to drive the subwoofer to 32.5mm xmax in a ported enclosure TBA cubic feet tuned to 32 hertz. This rating will vary depending on enclosure size and tuning.
Klippel results extrapolated from production samples and may vary without notice. Klippel testing was performed by Redrock Acoustics.
ENCLOSURE RECOMMENDATIONS
Sealed Volume: TBA System: Q .71
Ported Volume: 5 cft
Tuning: 30 hz
Port Area: TBA
Ripple: 6db
F3:25.75 hz
NOTE: All volumes are net and do not include port or subwoofer displacement. Enclosures are recommendations only and can be adjusted per the customer’s desired system response. Recommended enclosures do not consider transfer function
sorry yea i was being serious, i went and google it after i asked(my apologies again), but for what ever reason it didnt look like much pulled up. But yes i was asking a legit question. ive just never heard the name. I was looking at stuff on ebay the other day seen something that said DSS i believe but i didnt pay it any mind until i seen it mention in this thread
Hard to tell just reading sometimes. Lol They look like pretty solid subs. Looks can be deceiving though. If I had some extra cash layin around I'd preorder a couple myself.
yea if i had the money i wouldnt mind giving a 18" try. I would like to have a decent single 18 instead of my 15's. Nothing rong with them, just like single subs better. Also have always had better luck with them
Aren't you getting that 9518? Or did it fall through?
idk what the dude is doing so i guess im not getting it. He stopped responding idk. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
so now im working on possibly trying to sell or trade them. I dont mind keeping them though, they bang for what they are
Shittty. Guess he finally realized what he had. Lol
If your interest in those ethos i have someone who is selling some with little to no play time and still stiff. 2 etho 12's i think they are for 250$ each.
id rather have a single 18....
---------- Post added at 11:33 PM ---------- Previous post was at 11:33 PM ----------
thats what im guessing lol... he could have just told me that tho instead of leaving me in the dark lol
But i have a guy here locally that i think said he would trade me a DC XL 18 for them, which i still think is a good sub as well. What do you think?
I like that trade too. The xl should be a 3000 watt sub pretty easy. Rated at 2200, 3 inch coil.
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
956
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
LosIsATool
LosIsATool
Pensacola, Florida
TurdFergueson2
maylar
    Jun 2, 2024
    Jun 1, 2024
