New to box building 3 Cvx 15
  • 4
Hello, I am looking to construct a box for my 95 caprice. 3 kicker Cvx 15. I would like to have it ported. So any input would be wonderful thank you. Abu jus joined the forums. I love it
Do you already have the subs?
Darn you double poast
I need dimensions mainly. Well all of the above. Really I've never really built a specific kind of box that met its exact requirements
So you need someone to design you a box? Can't really help ya out there but post up the max dimentions of your trunk and ill see if I can come up with anything. Wanna go for just lows or what kinda music u listen to?
That's the thing. Im very bad in math. So I couldn't even come close to even agreeing with that unless someone took the time to explain that then I would understand but no one will so i just gather measurements an put em together...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I am wanting to go far into this hobby but I don't know where to start So I'm frustrated ..//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Go online and just look up box calculator. Figure out the displacement of the subs, recommended cu ft, and tune it to like 33-35hz, and try to go for like 18 square inches per cube of port area. If you have a android look up box tuning calculator on the playstore. It tells you everything. Gross volume (volume b4 displacement of port and subs), net volume, what your actual volume will be after displacement, and it tells you the port area, tuning, gives you a cut sheet, and it has wiring diagrams too. Pretty neat.
The crossover is just a pair of 3way, 300watt crossovers I picked up from from amazon. the subs I have are 8" Kicker FreeAir f8a I am looking...
4
834
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
467
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
656
Bass-in-Chevy93
Brookshire, Texas
Bass-in-Chevy93
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
