New system wiring + new head unit; while not removing factory head-unit.
  • 1
cossack23
Tampa
PROBLEM: Factory head-unit must remain plugged into the car as it controls misc electronic functions of the car. An entirely new audio system (head unit + amps + speakers + wires) will be laid out, essentially overlaying the factory setup.
QUESTION: I wish to install a 2nd head-unit to control the entire audio system. How do I go about attaching and powering the 2nd head-unit, without disabling the factory head-unit?
Is it a simple as "Y-ing" the Yellow/Red/Black wires?
All word of advice are sincerely appreciated.
1. Sure, it would function but it would look a little half arsed. Ideally you would use a distro block and run separate wires to each amp or...
780
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
318
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
668
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
cossack23
cossack23
Tampa
cossack23
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
