New speakers aren’t working in 2012 Honda civic
  • 3
JTJimmy24
CarAudio.com Newbie
Hello,
Recently I purchased a pair of Rockford Fosgate R1675X2 speakers for the front speakers of my 2012 Honda Civic EX. I bought through crutchfield, so it came with AI HSB524 adapter and Metra 72-7800 Speaker Harness. I installed them following their directions along with a youtube video. I used the harness instead of splicing the stock wires. After putting the new speakers in, they worked for a little bit then randomly shut off while driving. After taking the door panel out and unscrewing the speakers a bit from the adapter, they seem to work and it plays audio. But when I screw them in all the way, it makes a popping noise once and then shuts off. I contacted Crutchfield and they sent me a replacement set of speakers and suggested it could have shorted. After taking the original aftermarket ones out of the adapter, I noticed they worked again, but once I screwed them into the adapter fully in, they stopped playing again. I have taken the aftermarket ones out and put back in the stock ones and they are working completely fine. I don’t know what I am doing wrong or is wrong. I have both a new set of speakers and speaker harnesses that Crutchfield sent out as replacements, but am hesitant to try them out if they same thing is gonna happen to them also. Any help is appreciated, thanks.
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
205
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
186
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
361
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
502
JTJimmy24
CarAudio.com Newbie
JTJimmy24
Chicago
2RZ-FE
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
