New Product Announcements
Taramp's TW
Audio transmitter with wireless technology!
TW is an innovative product, simple and efficient, that will give you a new experience in relation to your audio product.
  • Audio transmission with high quality
  • Connect your system to different vehicles
  • Send the CD player signal straight into your system
  • ART Technology (automatic remote)
  • Frequency response from 10 Hz to 22 kHz
Racesport LED Headlight Conversion Kits
We have the newest product from Racesport available to order. You may know about HID kits to increase your visible light output, but LED headlights have several advantages:
  • No flickering
  • Wider tolerance for input voltages
  • No delay when powered on. Instant full output.
Specifications:
  • 5000K Light Spectrum - Very similar to natural daylight
  • 1800 Lumens of candle power
  • 25W power consumption
  • 30,000 hour life span
Kits are available for H4, H7, H8, H9, H10, H11, 5202, 9005, and 9006. More sizes are coming soon!
1 Year Manufacturer Warranty
  • No flickering
Specifications:
Hmmm pm me a quote on some h11s I think thats what I have
CDT Audio
HD-6100iEX 40 degree component coax
Audiophile 6.5” component cast alloy coaxial speaker with a 40 degree dispersion for superior imaging and staging.
Experience a component coaxial speaker with response and staging way beyond any other 6.5” in the market. Tweeter is mounted at a 40 degree angle for enhanced imaging and staging. This is the easiest quick drop in installation audiophile component coax speaker set in the market. CDT introduces a true audiophile 6.5” component coax woofer w/top of the line tweeter for your vehicle quick and easy installation. Finally a true component coax speaker with separate high-end EX-540 24dB crossover competing with top high-end component systems.
Suitable for use enclosed or free air in your vehicle, these drivers provide full, rich, smooth sound w/enhanced 40 degree imaging tweeter with sound performance never heard from a 6.5” coaxial woofer and tweeter before. If your listening tastes are for smooth sound with superior highs and bass response in smaller spaces these drivers provide optimum value and minimized installation cost. Designed and built to deliver accurate and natural sound performance never heard before from an easy to install 6.5” component coaxial speaker system.
HD-6100iEX
(HD-6100iEX.2 2 Ohm version)
2-way carbon reinforced 40 degree dispersion component coaxial speaker system
Technical specs and contents
  • 1 pr HD-E6 6.5” Carbon reinforced Mid-woofer
  • 1 pr 1.1” WS100i tweeter mounted at 40 degree angle on coax center post.
  • 1 pr EX-540 24dB Elliptic design crossover
  • Frequency response 55Hz-20.000Hz (40Hz-20.000Hz in ported enclosure)
  • Power handling: 190Watt RMS HPF 110Hz
  • Impedance 4 Ohm (2 Ohm available)
  • Sensitivity: 91.5dB
  • Mounting depth: 2.75” Diameter: 6.5” (165mm)
  • Woofer Cone: Reinforced Carbon Fiber
  • Magnet weight: 20 Oz
  • Magnet rubber boot is optional
Promotion price $259.99
Regular price:$359.99
Taramp's HD 400.4S
img.php
Class D Amplifier 400W RMS
  • 4 Channels
  • Max. Output Power @ 13.8 VDC 2 Ohms: 4 x 100W RMS
  • Max. Output Power @ 13.8 VDC 4 Ohms: 4 x 60W RMS
  • Max. Output Power @ 13.8 VDC 8 Ohms: 4 x 33W RMS
  • 3 Channels (stereo/mono) - 2 x 100W RMS 2 Ohms, 1 x 200W RMS 4 Ohms bridged
  • 2 Channels (stereo) - 2 x 200W RMS 4 Ohms bridged
  • Input Sensitivity: 250mV
  • Total Harmonic Distortion (THD) - 0.02%
  • Separation Between Channels (Crosstalk) - >70 dB
  • Signal/Noise Ratio - >95 dB
  • Damping Factor - >200
  • Frequency Response (full range) - 10 Hz - 38 kHz (-1 dB)
  • Fixed Crossover
  • HPF (High Pass Filter) - 80 Hz (-12 dB/octave)
  • LPF (Low Pass Filter) - 80 Hz (-12 dB/octave)
  • Input Impedance - 18K Ohms
  • Dimensions - 151 W x 51 H x 203 D mm
  • Weight - 0.63 kg
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
