New personal best with one sub =)
sundownz
Pro Seller
Supporting Vendor
11,349
North Carolina
155.1 dB - woohoo //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This was with a "Monster" prototype woofer -- not a production speaker.
Interestingly... with all my tweaks to the Z v.2 prototype it was doing the same numbers per watt up to 2500 watts (I stopped measuring with the Monster at that point). So... I may be able to match this with a full production trim Z v.2 driver.
Previous best was 154.9 with an 18v electrical system and two SAZ-3000Ds on the sub... this time I am on 12v but with two SAZ-4500Ds (power is similar).
Some more pics of the setup :
I haven't played with front to back box positioning since I built the new amp rack (yah, slacking... I know) -- but I'll work on that a bit when I get time and see if I can increase this.
What batts? and how many?
Car off?
Dipping voltage on burp?
I have six Stinger SPV-70s -- the lower end Stinger batteries.
I have it running but only @ idle.
I didn't measure voltage drop but my needle on the dash was pretty low when the burp was done //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I'd guess into the high 10s or low 11s.
Jacob....tape up the side openings on the pvc on top of box. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Absolutely nasty!
impressive.
more pics of the 4500's? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
These are the two prototypes -- the casing is not what production will look like at all.
Absolutely nasty!
I have a few other things I can do that I haven't done yet... when I did the 154.9 score I had 0.1 dB gain in putting another piece of PVC along the bottom of the port too. Haven't tried that again lately.
nice score. did u clamp to see how much actual power u were gettin? i am impressed. wha note? **** good job
I didn't put the clamp back in when I moved from one 4500D to two... so no, I didn't measure. It would be somewhere from 8 - 10kw, though.
  • Locked
The end. It’s more than obvious that these type “political threads” do no good for the forum.
116
4K
How low of an Fs do you look for? That Fs seems pretty low already.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
288
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
466
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
loudwhat?
    May 20, 2024
    May 20, 2024
