New head unit install - help needed
  • 1
jeffvb9
CarAudio.com Newbie
Installing a Jensen CAR710W head unit in my sons 2013 Volkswagen Golf. No steering wheel controls. I purchased the XSVI-9003-NAV wiring harness which is what Crutchfield recommended.
I am having a blue wire issue. I have 5 blue wires and not sure where these go to be honest.
1 from the antenna adapter - solid blue
1 from the AXSWC module that is a part of the XSVI-9003-NAV wiring harness - blue/pink
2 from the Jensen head unit - 1 solid blue (power antenna) and 1 blue/white (remote turn on)
1 solid blue from the XSVI-9003-NAV harness (instructions say this is not used in this application)
Connected everything up and it was working prior to actually mounting in the car. Once we mounted it the car would not turn over and the radio would not come in in Accessory mode (key turned once)
Any help is appreciated.
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
7
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
6
337
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
661
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
738
jeffvb9
CarAudio.com Newbie
jeffvb9
kansas city
jeffvb9
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
