new amp more power...less bass
I bet it's a crossover issue or impedance problem...make sure your crossover is set to around 70 or 80hz, if it's set too low you won't hear much bass at all.
i had to turn my LPF up.
it was all the way down and i threw it in and didn't check it. It was barely audible. I have mine at about half way.
you sure its wired to 1 ohm
what really gets me is that there are 4 spots for speakers to plug in but i have it wired the same way it tells me how to on the rockford fosgate wireing wizard....pos. to pos. neg. to neg. then pos. to pos and neg. to neg. on all coils
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
881
Thanks. That makes sense. It sounds pretty good as is.
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
AlpineUser
Bumpin
AlpineUser
St. Charles Mo
AlpineUser
