New amp gets hot when powered up?
One_crazy_dude
Hey all. Got an Orion xtr 2500.1 today. I removed a cab 1600.1 in working order just to add more power to my hdc 3.115 sub that is wired down to 1 ohm.
So I swap out power ground and remote wire and start the car. I do this to make sure it powers on. And power on it did. But I notices it was getting warm on the top half of the amp and in a minute or so it was hot but the bottom half is still cool. Mind you no rca's or speaker wires are hooked up yet so it's not loaded at all.
So I wait a good 10 minutes and it's hot but doesn't go into protect or anything so in plug in the 8 gauge speaker wires and rca's and music plays and plays loud but it gets hot. I played music for about a 1/2 hour and it has not gone into protect or anything.
I've had quite a few amps in my time and never had them get hot while just powered on and no signal going to it. Should I send it back? What would you do?
You use to could cook a steak on the old school Orion Reds back in the day but like a timex they kept on ticking
yeah but what size wire u have? hope 0ga.. it's tight.. but yeah some stuff just heats up fast man..
Power wire is 1/0 guage. I also have 3 100 ah agm batteries, 2 in back 1 in front. I understand amps get hot but this one gets hot while rca's and speaker wires are disconnected.
if im not mistaken, the MOSFETs are usually on the side of the PCB boards and would heat up exactly where youre talking about. I dont like the sound of this and wouldnt be too hesitant to return it. Its probably a repaired amp with either a poor repair job or wrong transistors installed during said repair. If its gettin pretty hot with no audio source nor speakers connected to it, thats a red flag to me. My SQ2200.1 stays very cool even when im beating on it fwiw
I agree. It is a new amp as far as I know of so I called amazon and it's going back. I just don't feel safe with this thing heating up for no reason. Thanks.
Was the amp new, refurb, or b stock, open box item when you bought it?
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
311
6
452
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
741
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
541
One_crazy_dude
One_crazy_dude
Jersey Shore
Louisiana_CRX
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
