SOLD New 4/3/2 Channel SONY XM-460G
  • 6
ciaonzo
TheContinental
11,703
76
WI
SONY XM-460G. ES line, of course. Very, very hard to find regardless of condition.
She's pristine, I just bought it brand new without the box and auditioned it for a couple weeks. Beautiful dynamic sound, very clean and powerful.
Real specs are nearly impossible to find on this but below are the specs for the 2 channel version. It's the old school SONY before they began making the power supplies that could be configured for either high voltage OR high current, like the HX series that made the same power in either mode. This one is not configurable for high voltage OR high current, instead it's rated for operation as low as 1ohm stereo and is overbuilt like quality old school amps were known to be. In fact, it's essentially two amplifiers in one heat sink as can be seen in the pics.
Known specs are 60 x 4 @ 4ohms. I would expect at least three times that at 1ohm as it had no problem driving my very demanding LMS sub without complaint.
4/3/2 channels, fused @ 2 x 30A. She runs just fine bridged @ 2ohms. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Specs update:
XM-260G
MSRP$ 500.00
60Wx2 at 4 ohms, 20-20kHz, at 0.03% THD
120Wx2 at 2 ohms, 20-20kHz, at 0.08% THD
180Wx2 at 1 ohms, 20-20kHz, at 0.1% THD
1 ohms Drive low impedance operation
240Wx1 at 4 ohms, 20-20kHz, at 0.08% THD
Discrete differential FET predriver stage
Discrete final stage w/MOSFET audio devices
Independent supply rails for predrive & final stage
Separate MOSFET power supplies for R/L channels
40Hz lo frequency EQ adjustable 0 to +10dB
Dual mode operation allows stereo & mono drive
Protection for temp, voltage & current faults
Balanced input circuit for noise isolation
$200 shipped.
Shipping included for CONUS.
lol
Sorry, Mike. I most likely caused your confusion because I posted the specs for the two channel, lol.
Gonna hang on to it, though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
no it was my fault since I forgot and then just quickly looked at the description.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
432
6
502
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
881
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
497
ciaonzo
TheContinental
ciaonzo
WI
gentlejax
Decebal
    Jun 10, 2024
