Need Subs
Alexlapp
I bought 2 new duals then my friend decided to mess with how i had my stuff wired, after he was done rewiring everything i tried to listen to my system when the power got into the amp the subs started smoking extremely badly and the voice coils are shot. this is the second time i had a sub where the voice coils burnt out i had 2 different friends decide they didnt like how my stuff was wiring and ended up ruining my subs so Im looking for a good deal on a new pair of 12s
i know for sure i can get 2 boss 12s 2300 Watts each for like 140 or less even that are brand new which is what i want to do i think im just seeing if i can get a better deal elsewhere
If ya wanna go cheap and sound decent get yourself some pioneer premier champions, or champion pros - WAYYY better than any dual / boss / pyle junk ;-)
you can get these for $99, you most likely will need to upgrade to a better amp later on
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Never seen these in action but they look pretty **** nice for the price! :)
They are very beefy and the sale is for just the first 100 orders then it bumps up to $129 which still a decent price and its free shipping
and how does everyone feel bout planet audio
Not worth it
Those pioneer champions/pros would work good for cheap
Really i woulssave up a bit a n get a nice pair of 600w 12s and a 1200-1500w amp quality cost but not so much it isnt affordable
Personally i would do 2 incriminator I12s on a 5.1 which runs arounds 500 and is a very goid starter system the 500w 5.1 is stronger than that boss amp and will last a lobg time if treated right
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Alexlapp
Alexlapp
Clintonville, WI
audiobaun
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
