Check the RCAs, they may have come off. Also check the amp settings. I have seen a few accidentally switched to high pass.Any thoughts?
I'm too much of a novice. RCAs on the back of the deck?Check the RCAs, they may have come off. Also check the amp settings. I have seen a few accidentally switched to high pass.
Yes the base is less if I use fader to only the front speakersI feel there is more to the story than just changing the batteries. Did you remove RCA cables? Did you move the head unit? Did you move the amplifiers? Try your fader... does the bass get less going front to rear or rear to front or left to right? If there is any change in the subs... check where your RCA's are connected.
I never changed anything. I believe there is a RCA connecter under the front carpet.Yes the base is less if I use fader to only the front speakers
I completly forgot about settings going back to zero when disconnecting battery.Try your fader... does the bass get less going front to rear or rear to front or left to right?
Yes base is less when playoff front speakers onlyI completly forgot about settings going back to zero when disconnecting battery.
On your radio settings, check for "Sub" output. If you have one, turn it on. If Sub setting has a volume, turn it up.Yes base is less when playoff front speakers only
