Need some wiring and sub calibration help
  • 2
Start with everything turned down. Turn up your LPF (low pass) to around 60hz. Set your Subsonic filter (if you have one) to around 15-20hz.
Power on the amp and play some music. Slowly turn up your gains listening for anything unusual. Since you haven't listed your head unit type/model, I can't advise you on what amount of voltage it puts out, to set your gains to. Usually I tune by ear, and rarely have to go above 1/3 - 1/2 way. Most amps will begin to have slight distortion when driven over 50-70% gain, so keep it below that if possible.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
488
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
598
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
suzukiguy02
suzukiguy02
minnesota
VWBobby
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
