Need recommendations
  • 1
Slayer16102
CarAudio.com Recruit
34
I currently have p3sd2-12 shallow mounted subwoofer in my car. It has an RMS Power Rating of 400w with 800w being the peak power.
I would like to change the sub and the setup to a 5 channel system, but I need your help for some recommendations.
My current build: Lacks that nice hard hitting bass
Wiring: 1 Gauge wire w/ (1) 200A monofuse block near battery
Headunit: Pioneer X6800BS 50 x4 sub 2v preouts | clean undistorted volume all the way up to 59 out of 62.
Door speakers: 6.5" Alpine SPS-610C 80 watts RMS / 240 watts max power. Not sure of the ohms.
Rear speakers: Factory 6.5 Bose Speakers
Sub Amplifier: Kenwood 9106D 500w RMS at 4 ohms or 1000w at 2 Ohms.
Subwoofer and enclosure: Rockford fosgate P3SD2-12 shallow mount sub 400w RMS 800w in sealed box with 0.86 Cuft of airspace
Other Amplifiers: None
Space Limitations: (Dual 8's, triple 8's, or dual 10's) max height of preloaded sub box 15" Tall x 44" accross x whatever depth
Music types: Rap, rock, bass, techno, dubstep, bass tracks (Almost all of my music is played thru youtube or thru the radio)
Considering buying a dual setup of kicker comp c's in either a dual 8 or 10 inch setup.
I want to buy a pre-loaded enclosure with the right amount of airspace on my new setup. I am open to all kinds of suggestions for audio system upgrades... Budget is right between $750.00-$1000.00 for the new setup.
Due to my space limitations of 15x44xwhatever do you recommend a single 10, dual 10's, single 8, dual 8's, or a triple 8 setup?
I'd love to do a dual 12 or even a 15" setup, but unfortunately I can't.
Will two dual 10's or even 8's that are full size hit harder than my current p3sd2-12?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Are you saying that I should replace the jack on the headunit with a wire instead? Is that fairly simple? I'd imagine you would just need to make...
8
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
The amp and sub are a bad combination. That sub is dual 2 Ohms. It can be wired to 4 Ohms in series or 1 Ohm in parallel. The amp can only go to 2...
4
I am building a nice system in my Ford Excursion using high end 3 way component speakers in the front doors in custom speaker pods, and using 2...
Slayer16102
Slayer16102
Slayer16102
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
