Need input and suggestions...
  • 3
craigzter
erm..hello.
4,908
sville, ar
Okay to start off, I have a regular cab 01 silverado and it is 5spd. I am planning on running a single 12 and locating box and sub in center console area. Anyone have any experience with this? I have been playing around with some drawings both paper and paint, not too inclined with sketchup lol. I am looking at ~2.5cubes @ 32 for a SQ HDS312 or possbly a DD 3512. Sub up and port forward is how I have it going now, suggestions on that is welcomed as well.
I just need some criticism on what I have came up with and just seeking some answers as to if it would sound good with what I have in mind. Any suggestions, input or whatever is welcome.
Thanks...attactched is a pic I done up in paint for just a general idea of what I need and max dimensions...though it can be redone by shortening the depth of the box and making it somewhat higher(up to around 16.5" external) the width is maxed out to 14-14.5" external.
Thanks fellas...
It looks find Craig. The dd subs love a lot of port I'd down fire tho I think. Or even a big sealed box. They'll surprise you
You think I could fit one of those AB vfl's in there with the room I have? Hate regular cabs for this purpose, been trying to find someone who has done a center console with a 5 speed truck, all I can find are autos. That shifter really messes me up on the full amount of space I need. My other option is to use the area behind the seats and bring the sub between the seats and forwards a little with port out bottom passenger side.
Thanks fellas...
You prolly can unless your like 6'+ tall. I did a reg cab dodge a while back for a member with a lvl 5. 15 made the box custom with a bit more room behind the drivers side. Most of the box and the sub was behind the pass side also had a amp rack built in the box with the amp behind the drivers side. Turned out really nice. And got deep and loud
Nice! Im 5'10'' got a little room to play with behind my seat. Passenger seat I have a little more room to play with as most people are shorter than me who ride with me, mostly I ride solo.
I was going to ask this wolla go but what about going with 4" aeros?!
You can. I did a slot port on the box bottom firing to the drivers side. It was like 3" x 6" x 18" long
Okay so if I did the single 12, hds312, behind the seats. I scooted my seat up enough to where I felt comfortable enough to drive/shift and im right at 9" on bottom and about 6-6.5" up top behind my seat and 52" across and 14" high o.0
Yep. And behind your seat. Recess the box a bit for the amp to mount there. Also the sub will be mounted as far down towards the bottom of the box so it will fit. You can also move the passenger seat up more to get another inch or two for mounting the sub
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
336
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
327
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
343
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
581
craigzter
erm..hello.
craigzter
sville, ar
mylows10
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
