Need help with speakers for Lexus LS430
  • 2
Dolo180
CarAudio.com Newbie
6
Al
Hey fellas I have a ls430 like the title states it doesn’t have the mark levinson system.It has the pioneer system haven’t been able to find if it has a factory amp and I’m wondering if I’m limited to a certain ohm speaker when upgrading factory subs and speaker any help will be much appreciated.
The ohm is usually stamped on the speaker or sub. You didn't say what year your car was. The 2003 has the following specs for the pioneer speakers:
Front doors 2 ohm, Rear door 4 ohm, Dash tweeters 6 ohm, and Rear Sub 2 ohm.
Another option is to go to youtube and type in the "Removal of factory amplifier for your car model and year." This will give you the location, and verify that you have one. You can also do that for your subwoofer replacement. Good luck.
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
5
Yes, one shop is absolute best and last time they let me return it even when i mounted it on the car and tried it :)
6
3K
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
8
Dolo180
CarAudio.com Newbie
Dolo180
Al
huberoy123
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
