Aygodriver1212
Hello guys,
I figured I'd make a new thread since the old one was just bumping the entire time and it went off topic.
With some help I chose for this subwoofer: GZTW 30TX
If you have a better sub to recommend at a price range of around 100 to 150 euro's please do recommend it first.
The T/S parameters of my current choice are right here;
http://www.ground-zero-audio.com/components/com_jshopping/files/demo_products/GZTW_TX_19042010_GZTW_38TX.pdf
http://www.ground-zero-audio.com/components/com_jshopping/files/demo_products/GZTW_30TX.pdf
I want to create a ported enclosure, bass-reflex pipe port preferred (I have a few ones available
you can find them down in the thread). As my name says, I have an Aygo. So I have limited space.
I took a new look at my trunk and re-measured. Seems I can fit a wedged shape box with these max outer dimensions. I think the width should be a variable since that's the biggest value here and the easiest to alter. I'm planning on using 18mm MDF, in inches that's about 0.7" I believe.
Can anybody help me calculate a box or even calculate one for me?
I'm looking to tune it to about 32 hz since I listen to a lot of hip-hop.
Different port sizes I have available right now are:
Ø 2" - adjustable length: min 5.9" - max 11"
Ø 2.5" - max length: 7.5"
Ø 2.6" - adjustable length: min 5" - max 9.6"
Ø 2.95" - max length: 4.7"
Ø 4" - max length: 4.5"
Of course I wish to reduce port noise as much as possible. Again, I've tried WinISD and it's just not
working out for me. No clue what I'm doing wrong...
I HOPE you can help me.
Thanks!
![maxininches2.png](/proxy.php?image=http%3A%2F%2Fwww2.pic-upload.de%2Fimg%2F30249414%2Fmaxininches2.png&hash=c5dc1282031c49fd592b5013bcec796d)
Thanks!
