Need A Little Help With Gluing Surround Back To Cone
  • 2
Well, this topic has probably been covered but I'm failing to find my exact answer. I have a Audiobahn AW1206Q 12" woofer that has a little separation between the foam surround and the cone. I'm 95% sure I can glue this. It's about a 4" separation.
My options for glue are no name superglue and Gorilla Glue. The Gorilla Glue seems promising, but I wanted a little help before I dove into it. I'm also curious how to effectively clamp the come to the surround during the drying process.
Any help is really appreciated. Thank you in advance!
Worked out a DIY cone to surround clamping system hahaha. It's the worst looking thing ever, but I have pressure up on the cone and even weight pressing down around the surround. If this doesn't work, I'll have to really find out what others have used to clamp the inner edge of the surround down to ththe cone. Also working on fixing a type r voice coil....
536
387
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
428
631
MrSlaybury
MrSlaybury
New Hampshire USA
MrSlaybury
