Multiple amp grounds
Jimg
CarAudio.com Regular
217
13
If running a 2-3 amplifiers system
and a dsp
After market headunit
1 Does it matter if they are all grounded at the same place with a grounding block
vs each having a ground at their own locations.
2. or is this just a have to do what ever option it takes to not have ground noise in the system
I have one wire going to the grounding point and then use a grounding distribution block sending out the ground to the amplifiers and soon the DSP when I install it. Never had an issue doing it that way for years and years. They make specific distribution grounding blocks.
I think you can test the voltage drop at different points in your electrical system. You can test your ground, I watched a nice video about it by (guessing a little here) CarAudioFabrication on YouTube.
A good ground will have low voltage drop? Or very low resistance?
But its a legit way to make sure your grounds are doing a great job.
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Jimg
Jimg
Jimg
    May 24, 2024
    May 23, 2024
