Multi amps, caps and crossovers questions
  • 1
fporro
What's the proper way to set this up...
radio has 3 rca outputs, front, rear and sub-woofer.
- Stinger 1.4 cap, big enough for JL Audio 1000/1 v2 ?
- Gravity 5.0 cap, big enough for multi amp setup ?, they are:
JL Audio HD600/4
JL Audio HD600/4
JL Audio HD750/1
- JL C2-525 speakers, do i need to hookup crossovers or are amp filters enough ? (600/4 amp)
- Alpine SPR-50 speakers, do i need to hookup crossovers or are amp filters enough? (600/4 amp)
- Speakers for HD750/1 amp, 8" for vocals, any recommendations ? to be door mounted.
- speaker cables, could I extend them ? about 2 ft max.
- RCA connections for HD750/1 amp, it used to be my sub-woofer amp, but planning to use it for vocals, could I share RCA betwen 2 amps without degradation ?
thanks and sorry for all this questions.
picture.php
picture.php
picture.php
picture.php
removed lead weight and place amps there instead.
HD750/1 offline until find suitable 10's.
two p3s 12" woofers driven by 1000/1 v2 amp ...
picture.php
picture.php
picture.php
picture.php
picture.php
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
190
Hi all, looking to add a pair of speakers to the outside of our caravan. Currently the van has 4 ceiling speakers running off the existing single...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
429
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
561
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
fporro
fporro
Malibu, CA
fporro
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
