MTX jh300 amp Issue!
  • 2
I installed the MTX Audio JackHammer JH300 600W, Class D in my truck. Powering two alpine type-s 10' subs. Im using a 50a fuse at the battery. 8 gauge B+ and ground. I had the subs working went for a drive and turned the truck off. The next time I turned the truck on the amp had the red + yellow light on and no power to the subs. The ground seems to be pretty good, I double checked all the connections.
Any help would be very appreciate as my car audio knowledge is somewhat limited. Thanks.
It probably blew, thats a very entry level amp (crap)
If not, make sure the fuse on your power wire matches the fuses in the amp. and check the fuses in the amp itself. Make sure your ground is to the frame with no paint on either side
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
831
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
106
Anthony Carlyle
Anthony Carlyle
Vancouver, British Columbia, Canada, Canada
Anthony Carlyle
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
