MTX 1000xd won't go out of protection mode.
  • 3
rbai76
So I bought an MTX 1000xd amp from classfields here. Im not sure if it works or not, I opened it up and didn't see anything blown or melted.
I also wired my cherokee with knukonceptz 0 gauge dual amp kit, fuses are all good. Only problem is when everything is connected and when the amp starts up it is green for like .5 seconds then turns to red and buzzes. Now could this be a grounding issue or do you think it could have to do something with the amp it self. The power is the problem because I have unplugged everything and plugged back in once at a time to see what the problem was and it is the power. I have sanded down the paint under the carpet in the back of my car and it is connected there. I have touched around a few spots but still in protection mode.
Tell me what you guys think
Thanks
are speaker wires connected during this time? if so, disconnect them.
Yes, I have done it connected and disconnected. I have tried with only power, ground and the remote power cables connected and still does it.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
858
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
596
rbai76
rbai76
Annapolis, MD
rbai76
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
