Mounting sub box
  • 4
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the penetration to have a rigid hold down. Then run a ratchet strap through the seat to the front wrapped and secure the enclosure to the back seat. Shouldnt move unless you roll the vehicle over a couple times
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
512
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
Furgis
Furgis
Earl Grey, Saskatchewan
audiobaun
    May 31, 2024
    May 24, 2024
