Morel MW5 Mids *2 pairs*
  • 2
blazian87
5.25" Morel MW5 Mids
I have 2 pairs used in decent good condition I would say. No rips or tears on surround. Few scuffs here and there on basket. Comes with original grills. They are the same mids you find from the Morel Hybrid 502 comps. No crossovers included.
Nominal Impedance: 4 Ohms
Power Handling: 120Wrms
Max. Trans.Pwr Handling: 500Wrms
Sensitivity (2.83V/1M): 90dB
Frequency Response: 45-3000 Hz
Resonant Freq. Fs: 56Hz
Voice Coil Diameter: 2.1in (54mm)
Voice Coil Height: 0.41in (10.50mm)
Voice Coil Type/ Former: Aluminum
Voice Coil Wire: Hexatech Aluminum
DC Resistance: 3 Ohms
Voice Coil Induct. @1 kHz: 0.21MH
Magnet System: Hybrid Rear Vented
HE-Magnetic Gap Height: 0.16inch4mm)
B-Flux Density (T.M.): 0.83
BL Product/BXL: 4.16
Max. Linear Ex./Xmax: ±0.14in (±3.5mm)
Suspension Compliance CMS - mm/N: 0.78
Electrical Q Factor QES: 0.59
QTS: 0.45
QMS: 1.8
Mech.Resistance RMS - Ohm/meter: 1.96
Moving Mass MMS - gr: 9.9
Equiv. Can Air Load VAS: 8.87L (0.31cu.ft)
Effective Piston Area SD: 90sq.cm 13.95sq. inch)
Cone Type: One-piece formed
Cone Material: DPC
Unit Diameter: 5.25in (135mm)
Mounting Depth: 2.36in (60mm)
Mounting Cutout: 4.27in (120mm)
Net Weight: 1.32lb (0.60Kg)
$220 shipped or PM for local pickup
on me
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
4
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
blazian87
blazian87
Los Angeles, CA
evilmonstertruk
