Morel elate 3 way limited edition speakers 010/500 very rare new
  • 2
TNT
St.Louis
Item(s) for Sale: MOREL 3 WAY ELATE LIMITED EDITION SPEAKER SET. NEW STILL IN PACKAGING. 010/500. VERY RARE SET.
Item(s) Description/Condition: NEVER PLAYED OR USED IN ANY WAY. PERFECT CONDITION
Woofer ELATE SW 6LE
Nominal Impedance 4 Ohm
Power Handling 200W
Max. Transient Power Handling 1000W
Sensitivity (2.83V/1M) 88dB
Frequency Response 25-4000Hz
FS 50Hz
Voice Coil Diameter 75mm (3.00")
Voice Coil Height 16mm (0.62")
Voice Coil Type/Former Aluminum
Voice Coil Wire Hexatech Aluminum
DC Resistance 4.10 Ohm
Voice Coil Inductance @1kHz 0.44MH
Magnet System Hybrid rear vented
HE-Magnetic Gap Height 6mm (0.25")
B-Flux Density 0.8T
BL Product/BXL 7.07
Max. Linear Excursion/Xmax 10mm (±5mm)
Suspension Compliance CMS 0.560
Mechanical Q Factor QES 0.44
Total Q Factor Q/T 0.37
QMS 2.21
Mechanical Resistance RMS 2.44kgS¹
Moving Mass MMS 16.5gr (0.58oz)
Equivalent Car Air Load VAS 11L (0.39ft³)
Effective Pison Area SD 119cm² (18.45in²)
Cone Type One-piece formed
Cone Material Carbon Rohacell Sandwich
Unit Diameter 165mm (6.50")
Mounting Depth 61mm (2.40")
Mounting Cutout 141mm (5.55")
Net Weight 1.18kg (2.60lb)
MIDRANGE CDM–88LE
Power Handling 100W
Max. Transient Power Handling 300W
Sensitivity (2.83V/1M) 89 dB
Frequency Response 450-7000Hz
FS 280Hz
Voice Coil Diameter 54mm (2.10")
Voice Coil Former Aluminum
DC Resistance 3.5 Ohm
Magnet System Neodymium rear vented
Dome Type Acuflex Soft Dome
Dome Material Silk
Unit Diameter 88mm (3.50")
Mounting Depth 21mm (0.83")
Mounting Cutout 75.5mm (2.97")
Net Weight 0.25kg (0.55lb)
TWEETER MT-24LE
Nominal Impedance 6 Ohm
Power Handling 130W
Max. Transient Power Handling 350W
Sensitivity (2.83V/1M) 90dB
Frequency Response 1400-25000Hz
FS 700Hz
Voice Coil Diameter 28mm (1.10”)
DC Resistance 5.2 Ohm
Magnet System Double magnet neodymium – H type
Dome Material Silk
Unit Diameter 45mm (1.8")
Mounting Depth 20mm (0.8")
Mounting Cutout 50mm (2")
Net Weight 0.07kg (0.15lb)
Crossover Accuset MX-33.3LE
Power Handling 250W
Crossover Point Power Handling
Woofer: 380Hz / 12dB
Midrange: Low 300dB 6dB, High 3800Hz 6/12dB (Variable)
Tweeter: 3800Hz 6/12dB (Variable)
Crossover Controls
Midrange upper frequency slope cut: 6/12dB
Midrange level: -2dB, 0dB, +2dB
Tweeter frequency slope cut: 6/12dB / octave
Tweeter level: -2dB, 0dB, +2dB
Wiring options Standard, bi-amp, bi-wire
Housing Material Die-cast aluminum
Terminal Type Fully insulated gold plated screw taps
Net Weight 1.20 Kg (2.65lb)
Price: $1200/ OPEN TO OFFERS
Shipping and Miscellaneous Item Information: I WILL SHIP USPS WITH TRACKING/INSURANCEView attachment 26539913View attachment 26539914View attachment 26539915View attachment 26539916View attachment 26539917View attachment 26539918View attachment 26539919View attachment 26539920
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
4
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
TNT
TNT
St.Louis
TNT
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
