mmats hd 4000.1d
Epic0318
FFFFFUUUUUUUUUUUUUU
mmats hd4000.1d
10/10 mechanical 9/10 exterior just because its used and theres one nick on the amp
$625 shipped
included in price
So, iv never owned an amp with double inputs.
Lets say im going to run it no lower than 2 ohms. Is it 100% required to use all 4 inputs for the amplifier to operate?
@FML to be honest i have no idea i ran all 4 connections at all times but im guessing you would have too. if you want i also have 2 distribution blocks that is 2 0 gauge in 1 0 gauge out that you can use it as one and 2 out to the connections
[quote name='Epic0318']@FML to be honest i have no idea i ran all 4 connections at all times but im guessing you would have too. if you want i also have 2 distribution blocks that is 2 0 gauge in 1 0 gauge out that you can use it as one and 2 out to the connections[/QUOTE]
Ok. Iv been in the market for a few weeks now waiting for something that ii really wanted. I don't imagine this will stay around very long, but ill keep an eye on it. Thanks
You'll have to use all the inputs on this
Made in the USA boosted rail
This is a team amp, no protection circuitry
The one in my car wired at 1 ohm clamped 4300 w rms after rise in the lanes at 13.8 volts
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
Epic0318
FFFFFUUUUUUUUUUUUUU
Epic0318
Goodyear, Arizona, United States
Grimmjoww
    May 16, 2024
    May 16, 2024
