maxxlink help
  • 2
i love spl
ok. so my plan is to put 2 hifonics 2500's to each sub. i plan on running 6 18's so i will have a total of 12 alps on the sub side. how many maxxlinks do i need since the hifi 2500's are not strappable? i have been told 2. one for every 6 amps. i have been told 3 one for every 4 amps and i have been told 6. one for every sub.. so whats the real anyswer? has anyone every played with one of these?
It straps amps into pairs. Basically all the Maxx Link does is send a 180* out of phase signal to the slave amplifier.
I recommend against using one at all. Just run one amp per coil and make sure to accurately gain match them all.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
94
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
424
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
397
i love spl
i love spl
baton rouge la
roarzorz
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
