materials needed
  • 3
Lschevelle
LA.
I need a list of materials that i will need to start my enclosure build. I want to use threaded rods for bracing but i can find none long enough so will be using wooden dowel rods. I will have to double baffle with 122 lbs or subs waiting to go it it. 17H 34W 33D it that helps
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
481
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
674
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
Lschevelle
Lschevelle
LA.
bubbagumper6
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
