Made to order grills, rings, Equipment for mounting speakers
I made for you. Supporting rings, holding the safety net, body parts, the volume for speakers.Equipment for mounting speakers. aluminum only. Steel Grid (Grid choice for photo or describe the specification). Dimensions can be any on the design or brand din and wishes in the form of external processing of the front surface - Decorative risk, polishing, Can painting. It's simple. Price by agreement.
Several options for photo:
"][/url]
"][/url]
"]http://[/url]
"][/url]
[/url]
More photos of my work here:https://yadi.sk/d/AMNurCZOqpaY8
Hi guys. In stock! Cost $ 130
This distributor under the crimped lugs on the wires.!
Power distributor for amplifiers or other devices. Under miniANL fuses. Two tier, compact.
Inputs: 1 pc. plus and minus - tip 2Ga (35mm2).
Outputs 5 pcs. - tips 4Ga (25mm2).
The case polyacetal black - is satined.
Connecting plates are nickel plated brass.
Cover plex.
Thread mounting lugs and fuses M6 (2Ga) and M5 (previous and 4Ga).
https://ibb.co/sWKjKVQ]
[/URL]
[/URL][/url]
Yes, what Dox said. The ++ -- makes it so you don't have to shove 4 wires into 2 connections. Convenient.
308
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
731
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
741
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
914
Alexander612
Russia, Rostov region
SilverSquared
    May 24, 2024
