fatboyracing 10+ year member
This is the lowest I will go on these I will keep them for less than this
lets say $28 on the router guide and $22 on the saw both for $50 these prices are shiped
This is a attactment for any router has different hole for all brands. This will let you cut perfict edges and cricles works great I no loner have a router so I have no use for this. Comes with everthing you need
this will make perfict staright cuts
The Accu-Rip allows the user of a right-hand blade circular saw to make straight accurate rip cuts, without the use of measuring tape or chalk line.
The Accu-Rip quickly attaches to the front of the base plate of a circular saw. The user can then adjust the sliding guide to desired cut widths from 1/16 to 24 in. The Accu-Rip does not have to be removed from the saw when making crosscuts. The level of skill to use the Accu-Rip is low. Lightweight and portable.
