Lock doors amp goes into protect mode
  • 3
ZDudas
I was giving a demo the other day and the guy in the passenger seat bumped my door lock switch and when he did my subs cut off. I looked at my amp and the RED L.E.D protect light was on. I backed the volume all the way down and it came back with power and played fine. I just don't understand why is does this?
Voltage dropping from doing so I bet.
Do you have a multimeter? You could check it out.
But what amplifier, charging system upgrades if any, et cetera is your system comprised of?
Stock battery up front. All stock electrical. Sub amp is a rockford fosgate prime r1000.1d monoblock powering 2 sundown sd-2 12's. I have a eBay volt meter wired directly to the sub amp and the lowest I've seen it drop to is about 12.5. When I start the truck the volt meter reads 13.6, but when I play full tilt it drops to 12.5.................
it is repeatable? that's frickin' weird. those two systems should be independent... unless you have a modern GM and the CAN bus is somehow tied to the remote turn-on wire...
what vehicle and what head unit/remote turn-on source?
how is power wired (direct to battery?)
Those are super nice!! I may have to go that route if by chance they don't fit.
19
205
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
408
6
492
ZDudas
ZDudas
Tupelo, MS
keep_hope_alive
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
